UDF COMPILING ERROR
Old   October 31, 2007, 10:36
Default UDF COMPILING ERROR
Sandilya Garimella
Hello, I am having a compiling error while reading a UDF into Fluent. However I am not able to get any details and cannot proceed with debugging my code. The following is the error I am getting
Deleted old libudf1\ntx86\2ddp\libudf.dll The system cannot find the file specified. (system "copy C:\Sandilya\Fluent\FLUENT~2\fluent6.2.16\src\makef ile_nt.udf libudf1\ntx86\2ddp\makefile") 1 file(s) copied. 0 (chdir "libudf1")() (chdir "ntx86\2ddp")()
Done. "c:/sandilya/fluent trials/ion stuff"
Opening library "libudf1"... Error: open_udf_library: The system cannot find the file specified.
Error Object: ()
can anyone tell me how to address this?
Old   November 1, 2007, 08:23
Default Re: UDF COMPILING ERROR
Sujay S
Do u have c compiler in that system???
Old   November 1, 2007, 08:33
Sandilya Garimella
yes I do have a compiler. My previous UDFs had run quite well and they were stored in the same folder as this problematic UDf that I am having issue with!!!!
Old   November 1, 2007, 08:43
Sujay S
When u compile a c program it will create a folder called libudf. u place tat folder and the text pad containing the c program in the place from which u have read the case file. After that u dont need to press the build button. U can directly press load button after reading the text pad
Old   November 1, 2007, 11:21
Sandilya Garimella
Thank you. It works now.
Accessing phi from a fvPatchField at same patch johndeas OpenFOAM 1 September 13, 2010 20:23
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." sega OpenFOAM Community Contributions 12 February 17, 2010 09:30
compile errors of boundary condition "expDirectionMixed" liying02ts OpenFOAM Bugs 2 February 1, 2010 20:11
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
user subroutine error CFDUSER CFX 2 December 9, 2006 06:31
