UDF rate equation
Old   November 7, 2007, 07:27
Default UDF rate equation
alp
just using fluent we identify only power law type reaction equation... but I have to enter a rate equation which consists of numeratior, denominator and summation... so do I have to use UDF? but I don't know C language... and it's hard to understand the tutorial
pleas help me....
Old   November 7, 2007, 11:59
Default Re: UDF rate equation
Allan Walsh
What kind of help are you looking for? In my experience with implementing a customized reaction rate with a UDF is that it can easily take several weeks. The example in the UDF manual is very straight forward.
If you are looking for advice, why don't you try putting your rate into the standard structure used by Fluent? Use something like Excel to plot your reaction rate versus temperature for your equation. Then look if you can approximate the curve with what is in Fluent. You may have to use different equations for different temperatures. You may have to fool with the temperature exponent or the stoichiometric coefficients.
Will there be other factors that control the reaction rate? Turbulence?
Old   November 8, 2007, 06:08
alp
-r=k1K1PCH4[sqrt(K2PO2)]/(1+K1PCH4+sqrt(K2PO2))^2
this type of rxn rate eqn. which is identified for reaction. and I think that your advice is not applied to this eqn.. so can you help me with a different way?
Old   November 8, 2007, 12:39
Allan Walsh
I guess not.
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
UDF for source term in momentum equation Enrico FLUENT 9 May 30, 2014 11:34
Volumatric reaction rate UDF elmcmaster FLUENT 8 October 6, 2010 05:22
UDF sources for energy equation el FLUENT 0 July 1, 2005 08:38
UDF sourse term for VOF equation ROOZBEH FLUENT 5 April 22, 2003 06:56
