UDF compile warning: no newline at end of file
Old   November 28, 2007, 03:03
Default UDF compile warning: no newline at end of file
mrt
Dear All,
I try to compile a simple UDF which is involving an inlet velocity profile. But I get this common warning :
It is explained in Fluent tutorial: "Another common error occurs when the argument list for a DEFINE statement is placed on multiple lines. (All DEFINE macro arguments must be listed on the same line in a C file.)"
My macro arguments are already on the same line (as seen below). Can anyone help me with this error?
with kind regards,
#include "udf.h"
DEFINE_PROFILE(axial_velocity,t,i)
real x[ND_ND];
real y;
face_t f;
begin_f_loop(f,t)
F_CENTROID(x,f,t);
y = x[0];
F_PROFILE(f,t,i) = 5.31*(1-(y/.05)*(y/.05));
end_f_loop(f,t)
Old   November 30, 2007, 12:43
Default Re: UDF compile warning: no newline at end of file
mohanraj
I din't see any error while compiling your code. I used "compiled" udf option and load the library using manage option(define->user-defined->functions->compiled & load library). I am able to see as a profile in the boundary condition panel.
Thanks, mohan
Old   December 1, 2007, 01:15
Default Re: UDF compile warning: no newline at end of file *NM*
suribabu
Old   December 1, 2007, 01:16
suribabu
i am not getting any mistake in your udf.
Old   December 5, 2007, 04:48
szz
This is a common compiler error. You simply need to add one new empty line at the end of your .c source code file before saving it. Then it should work fine.
Greetings szz
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
transient simulation of a rotating rectangle icesniffer CFX 1 August 8, 2009 07:25
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 11:46
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
