fatal signal (ACCESS_VIOLATION)
Old   December 10, 2007, 06:10
Default fatal signal (ACCESS_VIOLATION)
manu
I've written a quite complex (interpreted) UDF for transient boundary conditions that can be compiled without error message. But as soon as I activate it in Fluent, I get this error message:
FLUENT received fatal signal (ACCESS_VIOLATION) 1. Note exact events leading to error. 2. Save case/data under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. Error Object: ()
If I activate it with a test case file (a simple straight tube), it seems to be accepted but as soon as I use a dat file or when I initialize the solution, I get the error message mentioned above. Does anybody know what to do?
SOFC fatal signal (ACCESS_VIOLATION) inoxrocks FLUENT 2 January 22, 2015 09:20
FLUENT received fatal signal (ACCESS_VIOLATION) jwt FLUENT 2 July 1, 2010 08:35
FLUENT received fatal signal (ACCESS_VIOLATION)??? Jinfeng Fluent UDF and Scheme Programming 1 October 19, 2009 11:03
fatal signal yashar afarin FLUENT 0 April 17, 2006 11:07
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 15:16
