Velocity angles
Old   December 6, 2007, 11:41
Default Velocity angles
Usman
Dear I need assistance regarding velocity angle in 3D. When in profiles i select any surface and ask the fluent to write velocity magnitudes along with velocity angle it gives the angle values between 0 to +2.9 and 0--2.9 etc .Now whether this angle is in radians or in deg. and what is the reference axis of this angle, all this is unclear. Second is that i have a meandering channel with floodplain which is straight and i want to get velocity values perpendicular to a cross section within the meandering channel. This section is not perpendicular to entire domain that is not with reference to global axes but local axes of that particular section of the meandering channel. Now how can I get velocities perpendicular to this x-section.
Plotting Radial Velocity and Tangential Velocity in CFD Post ashtonJ CFX 5 July 13, 2015 02:49
help with UDF for contact angle based on contact line velocity gandesk Fluent UDF and Scheme Programming 14 October 29, 2012 13:58
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
