eulerian model
Old   November 24, 2007, 05:13
Default eulerian model
mvee
Hi I want to know @ eulerian model. Can it be used to analyze gas-liquid flow? for which regime (stratified, bubbly, slug, annular etc.) can it be useful? From the fluent literature i understand that eulerian model is used only for fluid solid and fluid fluid type.
thanking you, mvee
Old   December 6, 2007, 11:47
Default Re: eulerian model
lurk
a gas is also a fluid. i have used the eulerian model a bit, but it's quite complex. if you are going to see the different phases the best thing is to use VOF and the geo-recon scheem. in this model you can define the surface tension. regards lurk
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
question about eulerian model for packed bed rone FLUENT 2 July 19, 2007 20:58
Mass and het transfer using eulerian model Pablo FLUENT 0 February 16, 2007 08:36
the Eulerian model and the lower volume fraction hx li FLUENT 2 October 27, 2005 06:17
Strain Rate in eulerian model galeazzo FLUENT 0 January 25, 2005 07:52
