contour of 3d velocity magnitude as data file |
January 24, 2008, 00:13 |
hi How can I save the results of a 3d velocity field as a data file (x,y,z) in order to plot it in other application? I would like to obtain a similar plot like the -contour plot- obtained in Fluent postprocessor, but using a different software. thanks.... fran
January 24, 2008, 00:19 |
Re: contour of 3d velocity magnitude as data file
hi... searching in the forum I found the answer.... thks anyway
File-> export |
wmake compiling new solver | mksca | OpenFOAM Programming & Development | 14 | June 22, 2018 06:29 |
How to indicate velocity magnitude in tecplot with Flow-3d file? | his124 | FLOW-3D | 1 | June 27, 2011 10:54 |
paraview installation woes | vex | OpenFOAM Installation | 15 | January 30, 2011 07:11 |
[OpenFOAM] Paraview command not found | hardy | ParaView | 7 | September 18, 2008 04:59 |
Compiling OpenFOAM13 on AMD64 with Redhat Enterprise | mbeaudoin | OpenFOAM Installation | 20 | June 17, 2008 06:43 |
