February 8, 2008, 09:29 |
Fluent 6.3 on a Linux cluster
I'm working on a Linux cluster 32 bits, 5 nodes at 1.7 GHz and 2 GB of RAM on each node, the Fluent version is 6.3. Well, I've done the same calculation on my Core Duo laptop 1.6 GHz and 2 GB of RAM, Linux on 32 bits - a simple 2D calculation, and ... the solution converged faster on my laptop. This is something normal ? I mean a five nodes cluster should be much faster than my laptop. Thanks in advance. |
February 8, 2008, 09:50 |
Re: Fluent 6.3 on a Linux cluster
What is the cell count? Very low cell counts dont scale well over a cluster. You need >100k cells per cpu core.
February 8, 2008, 09:54 |
not necessary you should use your cluster with 3d calculations or with a minimum of cells. try the same with a 3d model, you should see the difference
February 8, 2008, 10:01 |
I use for this problem a very dense mesh 300000 cells, your suggestion is to use only 3 processors for the job ?
February 8, 2008, 11:09 |
I dont bother with parallel under 300k cells PER CORE i.e. minimum 600k cells per dual core machine.
fluent 12.1, batch mode in linux | sakalido | FLUENT | 13 | September 27, 2017 08:55 |
Fluent 6.3 32bit vs Fluent 12.0 64bit | ibex7 | FLUENT | 7 | April 18, 2011 02:44 |
Fluent 12.1 on Linux x64 Architecture Issue | fivos | FLUENT | 5 | April 24, 2010 15:19 |
FLUENT in Linux | L3munoz | Hardware | 4 | October 29, 2009 04:58 |
Fluent on Linux Cluster | george | FLUENT | 0 | August 11, 2006 04:57 |
