Convergence Criteria
Old   February 14, 2008, 16:31
Default Convergence Criteria
edwin
I am having some doubts over some convergence issues. The default convergence criteria for fluent is 0.0001. So if my solution converge with the default criteria it is correct? For a change, i set a very high convergence criteria 10^-10 my residual graph keeps going down until a point where everything starts to be in a straight line(constant), Do i use that results? it seems to be a more reliable result.
Old   February 14, 2008, 19:24
Default Re: Convergence Criteria
Phil
when your results are converged, they stop changing.
ie. check then check again 100 iterations later, if they look the same then they are converged.
Force can not converge colopolo CFX 13 October 4, 2011 22:03
What value shall I set for the Convergence criteria? steventay CFX 7 May 14, 2010 12:44
convergence criteria iuaniu CFX 3 September 24, 2009 19:20
Convergence criteria PrandtlGlawert FLUENT 1 August 13, 2009 18:06
Convergence criteria PrandtlGlawert Main CFD Forum 1 August 13, 2009 17:13
