Higher order polynomial problem...
Old   February 20, 2008, 16:44
Default Higher order polynomial problem...
Markas
Hello friends, yesterday i faced one problem and i m still searching answer for that, but couldnot. In my simulation i was having material properties at different temperatures. So i thought to define viscosity as a function of temp with help of Polynomial equation which is avalibale in fluent. i used higer order of polynomial(6 order). i found that solution was showing diverging behaviour. After that i took polynomial of lesser order(second order) in that case solutions was moving towards convergence. so why higher order is giving diverging solution?
1st order vs 2nd order ken FLUENT 8 March 14, 2013 03:43
modify fvMatrix / coupled equations / higher order diffusion Jinming OpenFOAM Programming & Development 0 May 7, 2011 06:20
Unstable flow simpleFoam 2nd order Valle OpenFOAM 0 August 26, 2009 08:12
Higher order Gradient Calculation CFDtoy Main CFD Forum 3 February 13, 2009 04:42
Higher order for phase volume fractions? George Bergantz CFX 2 December 11, 2000 11:55
