Setting up a 32bits server with more than 4GB
Old   February 20, 2008, 09:12
Default Setting up a 32bits server with more than 4GB
HSeldon
Hi, Since CFD is Hardware-intensive application, and also I work with fluids I thought that this site would be the best place to ask this: With a bunch of friends, we are planning to buy and old server (IBM Xseries with 8 Xeonīs) in order to run CFD on it. Hereīs my question. If those Xeonīs are 32 bits processors, but that server supports up to 16GB RAM, how I have to configure the OS (linux 32bit) in order to use more than those famous 4GB associated with the 32bits systems? I hope I was clear... Iīll have 16GB RAM in a 32bit system, so can I use the full power of the 8 Xeons and all that RAM?
Thanks a lot and sorry for my argentinian english. P.S: also I donīt want a full explanation. I donīt want to bother you. Just tell me if itīs posible or will be a waste of money.
Old   February 21, 2008, 02:55
Default Re: Setting up a 32bits server with more than 4GB
msrcm
since it is a shared memory architecture, run a fluent parallel version with 8 processes. this way i think you can make full use of it
Old   February 21, 2008, 08:00
HSeldon
Great! thanks for the info msrcm!
CFD Online Back on Main Server pete Site News & Announcements 0 March 31, 2011 18:14
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 21:58
Setting up a 32bits server with more than 4gb RAM HSeldon Main CFD Forum 4 February 21, 2008 11:45
Warning 097- AB Siemens 6 November 15, 2004 04:41
CFD Online Server Load Jonas Larsson Main CFD Forum 0 March 13, 2001 14:29
