UDF problem/32 bit vs. 64 bit
Old   February 21, 2008, 15:44
Default UDF problem/32 bit vs. 64 bit
RE13
Hello all,
I was wondering if someone would know of a work around for a problem I am facing. I have a complicated UDF that I have been working with for some time now on a 32 bit machine and it works great. Now I am trying to compile this UDF on a 64 bit machine but to no avail. I even tried pulling over my old case/data files that have the compiled library with them but Fluent did not load the library on the 64 bit machine. Do I need to have a 64 bit version of Fluent installed? (I am working on Linux)
Thanks in advance
Andrew
Old   February 24, 2008, 19:20
Default Re: UDF problem/32 bit vs. 64 bit
Aidan
you need to install the 64bit version of Fluent and compile the UDF in 64bit using the 64bit version of Fluent. You can also run the 32bit version on a 64bit machine.
Old   February 25, 2008, 11:31
RE13
Thanks!
udf windows 64 bit somasundaram Fluent UDF and Scheme Programming 0 October 3, 2011 23:37
help: udf compiling problem on 64 bit windows XP Hsieh FLUENT 2 September 10, 2009 04:51
UDF problem with 64 bit operating system? phillerup Main CFD Forum 0 July 23, 2009 13:00
why does not udf source file wor on 64 bit system? Jason K FLUENT 2 January 4, 2009 16:11
UDF Compiling Problem (64 bit machine) woo meng wai FLUENT 0 October 23, 2007 23:14
