please help to patch volum of secondary phase VOF
Like Tree1Likes
  • 1 Post By zidouni
Old   February 27, 2008, 04:13
Default please help to patch volum of secondary phase VOF
zidouni
I am using VOF to modelise a jet plunging into a water tank I initialise all the parameter to default value ( secondary phase(water) fraction volume is set ZERO. I creat a register using : adapt/region/I select the bounsaries of the water volum that i want to patch / I click mark A register named hexahedron-r0 is created
so I do this:
Solve / initialise/ patch/ select hexahedron-r0 + volume fracion of water=1/ I click patch.
theser is no message is given in fluent
In ordrer to check my patched volum I displayed contour/ phases/ water volume fraction : So I see that: all the domaine is water (( all volum fraction of the calcul domain is equal to 1 ))
please help me to find what is wrong
thank you Mr Gernot for your remarks. I check the contour and initialisation as you say but it seems this is not the probleme.
thank you very much in advance
Paskal likes this.
Old   February 27, 2008, 05:46
Default Re: please help to patch volum of secondary phase
Gernot
When you mark your region in the adapt panel, fluent tells you how many cells are marked ( for patching later ). Is this number of cells reasonable for your area? You can have a look at your marked area in the adapt/region/manage panel with display. If its possible ( depends on your geometry) i would prefer to mark your zone with adapt/iso-value and (for example) grid y-coordinate. Your way is the right one.
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 04:38
CheckMeshbs errors ivanyao OpenFOAM Running, Solving & CFD 2 March 11, 2009 02:34
how to patch a volum of secondary phase using VOF zidouni FLUENT 1 February 26, 2008 02:18
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
