February 27, 2008, 12:46 |
problem with static pressure
Hi, I've a problem with the static pressure.My geometry consist in a pipe, with a diameter of 2,5mm and a lenght of 29mm, inside to another pipe, with a diameter of 4mm, that after 20mm to the end of the first pipe presents a bifurcation.I have imposed as a BC, at the input of the pipe, a velocity equal to 0.8m/s and at the end of the two branches of bifurcation a gauge pressure of 0 Pa.I have used k-epsilo model. I have obtained that the static pressure at the end of first pipe is negative. So I wonder: -How can be the static pressure negative and then become zero? -Why the pressure drop is different from what I expect from theoretical calculations? Where I have wrong? Please help me!!! Thanks a lot
Nina |
fprint problem | MASOUD | Fluent UDF and Scheme Programming | 5 | October 30, 2011 16:08 |
CFDesign and Static Pressure within Solids | royaltrude | Autodesk Simulation CFD | 2 | August 25, 2010 19:59 |
UDF to define or adjust pressure??? | engahmed | FLUENT | 0 | July 6, 2010 17:19 |
Static vs Total Pressure | Alfonso Ferrandez | FLUENT | 2 | May 23, 2000 08:53 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 15:00 |
