Multiphase simulation of friction stir welding |
November 17, 2020, 07:07 |
mohammadreza
Rep Power: 6 |
Hi everyone
I'm trying to simulate an FSW weld with two different materials. In this work, I should put heat flux on the wall. This heat flux comes from the multiplication of the friction coefficient and perpendicular pressure. Because of the difference between the materials' friction coefficient, there will be a difference in heat flux. And I should know that where is which one. so I'm using C_VOF in my UDF, but because there is not any macro for VOF on a face, I'm using "C_VOF (F_C0 (f, t), THREAD_T0 (t)))", but when I want to initialize the solution, fluent crashes out with these messages in the error log file: Error [node 999999] [time 10/24/20 13:57:27] Abnormal Exit! Node 0 Fatal signal raised sig = Segmentation fault Error [node 0] [time 10/23/20 13:47:28] Abnormal Exit! I should mention that I try both interpreting and compiling UDF schemes, and both are the same. The picture of the message before the crashes are also attached. Can anyone help me or guide me where I'm wrong. this is the body of my code: DEFINE_PROFILE(heatflux_slip_shoulder_W, t, i) { face_t f; double pi = 3.1415927; double w = 1120; double U = 0.002; double press = 12700000; double delta = 0.9; double etta = 0.7; double heat_ratio = 0.6383; begin_f_loop(f,t) { double p[ND_ND]; /* this will hold the position vector */ double x, y, r, sigma_6, sigma_5, tav_6, tav_5, tav, fric, qslip, FV; double temp = F_T(f,t); FV = C_VOF(F_C0(f,t),THREAD_T0(t)); F_CENTROID(p, f, t); x = p[0]; y = p[1]; r = sqrt((x*x) + (y*y)); ********* for simplicity and not bothering you, I remove the body of code here************ F_PROFILE(f, t, i) = heat_ratio * qslip; } end_f_loop(f,t) } Sincerely Mohammad Reza |
Multiphase simulation of friction stir welding | mohammadreza_hj | Fluent Multiphase | 2 | November 17, 2020 03:15 |
Friction stir welding simulation | sid4512587 | FLUENT | 2 | November 23, 2016 21:05 |
Multiphase heat exchange simulation | efer2109 | STAR-CCM+ | 1 | September 15, 2016 13:22 |
Analysis of Friction Stir Welding | vishnuprakashs | Structural Mechanics | 0 | April 6, 2016 03:23 |
friction stir welding | raj | FLUENT | 1 | December 20, 2009 14:18 |
