evaporation on the surface of liquid nitrogen
Old   March 3, 2008, 04:37
Default evaporation on the surface of liquid nitrogen
dodo
i want to simulate a open tank in which liquid nitrogen is partially filled.when heat from outside is applied on the wall,natural convection occurs and evaporation takes place at the interface(surface).
1,how to use udf to simulate evaporation in this problem?i have got a udf code including three parts source,but in this problem,the evaporation only occurs at the interface and the interface changes always.
2.how to add the initiative interface position to fluent,if the liquid nitrogen is filled half
thx,dodo
[ICEM] Automatic mesh generation script surface intersection problem stuart23 ANSYS Meshing & Geometry 0 May 13, 2011 01:10
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 12:43
Best front tracking method for surface evaporation Komkamol Main CFD Forum 0 July 17, 2009 10:23
evaporation from liquid surface to ullage? prasanth FLUENT 0 May 22, 2003 08:23
evaporation from liquid surface to ullage? prasanth FLUENT 0 May 22, 2003 08:22
