Axial, Radial, Tangental velocity in FLUENT post
Old   March 4, 2008, 04:51
Default Axial, Radial, Tangental velocity in FLUENT post
Barri
I used SRF to model a compressor. I would like to show the axial, radial, tangential velocity on an iso-surface. Does anyone know how to show it in FLUENT post.
Thanks a lot!
Old   March 5, 2008, 10:39
Default Re: Axial, Radial, Tangental velocity in FLUENT po
SA
simpley go to contour menu
Old   March 6, 2008, 20:29
Hirdesh
1st create iso-surface in axial, radial and tangential at desired level. then go to contour menu. select velocity-velocity magnitude. then "from surface"-selct axial, radial or tangential option, as u create n want to plot.
Velocity Fluctuations in Fluent Andrew FLUENT 14 August 24, 2015 00:26
RMS velocity and reynolds stres with fluent gina FLUENT 1 May 20, 2013 04:05
difference of velocity field processed by CFD-POST and Fluent Jiuan CFX 3 June 16, 2010 08:23
Radial Position and Axial Velocity Graph Sal FLUENT 2 August 1, 2007 09:29
User defined rotational velocity in FLUENT Abhinav FLUENT 1 June 10, 2003 08:31
