March 9, 2008, 07:26 |
Drag UDF
hi as an exercize, i tried to specify the drag closure (Morsi-Alexander) explicitly through a udf, for a gas-liquid two phase flow. I am using euler-euler model and k-epsilon for turbulence.
The problem is that the simulation runs for some time and then says Invalid No: Floating Point error after say 500 time steps I am confused as to what could be the problem. this is the code.. someone please help me out #include "udf.h" #define diam 0.001 DEFINE_EXCHANGE_PROPERTY(custom_drag,cell,mix_thre ad,s_col,f_col) { Thread *thread_g, *thread_l real x_vel_g, x_vel_l, y_vel_g, y_vel_l, abs_v, slip_x, slip_y, rho_g, rho_l, mu_l, reyp, tau, void_g, void_l, a1, a2, a3, cd, f_drag, k_drag; thread_g = THREAD_SUB_THREAD(mix_thread, f_col);/*gas*/ thread_l = THREAD_SUB_THREAD(mix_thread, s_col);/*liq*/ /*geting the velocities and properties*/ x_vel_g = C_U(cell, thread_g); y_vel_g = C_V(cell, thread_g); x_vel_l = C_U(cell, thread_l); y_Vel_l = C_V(Cell, thread_l); slip_x = x_vel_g - x_vel_l; slip_y = y_vel_g - y_vel_l; rho_g = C_R(cell, thread_g); rho_l = C_R(cell, thread_l); mu_l = C_MU_L(cell, thread_l); /*slip velocity*/ abs_v = sqrt(slip_x*slip_x + slip_y*slip_y); /*Relative Reynolds No:*/ reyp = rho_l*abs_v*diam/mu_l; /*relaxation time*/ tau = rho_g*diam*diam/18/mu_l; void_g = C_VOF(cell, thread_g); /*gas vol frac*/ void_l = 1.0 - void_g; /*liq vol frac*/ if(reyp < 0.1) { a1 = 0.0; a2 = 24; a3 = 0.0; } else if(reyp < 1.0) { a1 = 3.69; a2 = 22.73; a3 = 0.0903; } else if(reyp < 10.0) { a1 = 1.222; a2 = 29.1667; a3 = -3.8889; } else if(reyp < 100.0) { a1 = 0.6167; a2 = 46.5; a3 = -116.67; } else if(reyp < 1000.0) { a1 = 0.3644; a2 = 98.33; a3 = -2778.0; } else if(reyp < 5000.0) { a1 = 0.357; a2 = 148.62; a3 = -47500.0; } else if(reyp < 10000.0) { a1 = 0.46; a2 = -490.546; a3 = 578700.0; } else { a1 = 0.5191; a2 = -1662.5; a3 = 5416700.0; } /* now calculating cd*/ cd = a1 + a2/reyp + a3/reyp/reyp; /* now calculating f*/ f_drag = cd*reyp/24.0; /*now calculate k*/ k_drag = void_l*void_g*rho_l*f_drag/tau; return k_drag; /*return drag coeff*/ } thanx in advance |
March 10, 2008, 08:33 |
Re: Drag UDF
hi it may be that you using a integer one place and float all the other places. it's here: if(reyp < 0.1)
{ a1 = 0.0; a2 = 24; a3 = 0.0; try using a2 = 24.; i had the same problem myself -lurk |
Pressure drag, friction drag and total drag? | Cheng | CFX | 9 | January 26, 2024 13:46 |
drag for AUV | saran | Main CFD Forum | 1 | October 6, 2016 06:59 |
DRAG | Diego Flores | FLUENT | 4 | April 17, 2011 07:48 |
Ram Drag | Socrate | FLUENT | 0 | May 23, 2007 03:14 |
UDF for Drag | Srivatsan | FLUENT | 1 | January 2, 2007 07:13 |
