udf problem of premixed combustion
Old   March 17, 2008, 06:31
Default udf problem of premixed combustion
wuyu
I try to use udf to define the resource term of premixed combustion, and I just follow the example of the tutorials, however when I interpreted the .c file, I got the problem as follow;
line21: function "Compute_Trb_Vscal" not found(pc=6). line21: function "Calculate_unburnt_rho_and Xl" not found(pc=86)
the code is like this: #include "udf.h" #include "sg_pdf.h" /* not included in udf.h so must include here */
DEFINE_TURB_PREMIX_SOURCE(turb_flame_src, c, t, turb_flame_speed, source) { real up = TRB_VEL_SCAL(c,t);
real ut, ul, grad_c, rho_u, Xl, DV[ND_ND];
ul = C_LAM_FLAME_SPEED(c,t);
Calculate_unburnt_rho_and_Xl(t,&rho_u,&Xl);
if( NNULLP(THREAD_STORAGE(t,SV_PREMIXC_G)) ) { NV_V (DV, =, C_STORAGE_R_NV(c,t,SV_PREMIXC_G)); grad_c = sqrt(NV_DOT(DV, DV)); }
ut = ul*sqrt( 1. + SQR(up/ul) ); *turb_flame_speed = ut; *source = rho_u*ut*grad_c; }
combustion model in premixed combustion chamber wuyu FLUENT 9 February 16, 2018 10:40
temperature problem with non-premixed combustion vic yang FLUENT 3 June 5, 2008 00:50
Sawdust Combustion-Non-premixed Combustion Model Jessy FLUENT 1 June 19, 2007 10:59
A problem about partly premixed combustion Z.P.YAO FLUENT 3 January 8, 2006 06:19
Non premixed model - combustion validation problem David FLUENT 2 October 24, 2003 10:06
