Fluent UDF - Random Noise
Old   March 18, 2008, 10:28
Default Fluent UDF - Random Noise
Tanner
I am trying to implement a constant time dependent (step) velocity normal to the boundary at the inlet of my simulation. I would also like to include some random nosie with zero mean. I am not an expert in C but i patched together the script below:
#include "udf.h"
#include "stdlib.h"
DEFINE_PROFILE(Velocity_profile,thread,index) {
face_t f;
double Flow_Time;
double U;
double Random_Number_Array[100000] = {0.0};
double Mean = {0.0};
int Number_of_Face_Nodes;
int i;
int Counter = {0};
//Find number of nodes on face//
Number_of_Face_Nodes = F_NNODES(f,thread);
//Find simulation time//
Flow_Time = RP_GET_REAL("flow-time");
if (Flow_Time < 1.0)
U = 1.0;
else
U=2.0;
//Generate Random numbers for each node on inflow face//
//The range is set to -0.5 to 0.5//
for (i=1 ; i < Number_of_Face_Nodes ; i++)
srand();
Random_Number_Array[i] =(((double) rand()/(double) RAND_MAX)-0.5)*((double) 2);
Mean = Mean + Random_Number_Array[i]; }
Mean = Mean/(double) Number_of_Face_Nodes;
//Ensure that mean is zero//
{Random_Number_Array[i] = Random_Number_Array[i] - Mean;}
begin_f_loop(f,t)
Counter = Counter + 1;
//Velocity at each node is U + differenc Random fluctuation//
F_PROFILE(f, thread, index) = U + Random_Number_Array[Counter];
end_f_loop(f,t) }
I think this is a good start though I cannot get fluent (6.3.26) to interpret it. I get the error:
cpp -I"/work/tanner/cx1_Fluent/Fluent.Inc/fluent6.3.26/src" -I"/work/tanner/cx1_Fluent/Fluent.Inc/fluent6.3.26/cortex/src" -I"/work/tanner/cx1_Fluent/Fluent.Inc/fluent6.3.26/client/src" -I"/work/tanner/cx1_Fluent/Fluent.Inc/fluent6.3.26/multiport/src" -I. -DUDFCONFIG_H="<udfconfig.h>" "/work/tanner/LES_Unsteady/OCPS2_Forced/test.c" In file included from /work/tanner/LES_Unsteady/OCPS2_Forced/test.c:2: /usr/include/stdlib.h:33: stddef.h: No such file or directory In file included from /usr/include/sys/types.h:31,
from /usr/include/stdlib.h:433,
from /work/tanner/LES_Unsteady/OCPS2_Forced/test.c:2: /usr/include/bits/types.h:31: stddef.h: No such file or directory In file included from /usr/include/stdlib.h:433,
from /work/tanner/LES_Unsteady/OCPS2_Forced/test.c:2: /usr/include/sys/types.h:147: stddef.h: No such file or directory In file included from /usr/include/stdlib.h:606,
from /work/tanner/LES_Unsteady/OCPS2_Forced/test.c:2: /usr/include/alloca.h:25: stddef.h: No such file or directory Error: /usr/include/stdlib.h: line 108: syntax error. cpp: output pipe has been closed
I would certainly appreciate some help. I'm not sure how to get fluent to find the stdlib.h though it is installed on my computer. Many thanks.
Old   March 19, 2008, 06:38
Default Re: Fluent UDF - Random Noise
Tanner
I have managed to hook the UDF I wanted using the compile function rather than the intrepreted function.
My only concern now is how often the UDF is updated. I want a random profile at each time step NOT iteration.
I have found that including an "if (first_iteration)" statement produces works for unsteady PISO but is this suitable for NITA?
How frequently are profiles updated for NITA? How can I tell it to update at the start of each time step?
Old   May 29, 2014, 03:27
Svetlana Tkachenko
Светлана is on a distinguished road
looking at your code, it looks like U is "1.0 + random noise" on the first time step, and "2.0 + random noise" on next time steps. Would you happen to know how to make it "U_old + random noise" instead please?
Светлана is offline   Reply With Quote
Random Injections Lior FLUENT 0 November 8, 2004 03:07
how to call the random function in Fluent Yong FLUENT 3 April 6, 2004 03:52
random number in Fluent Yong FLUENT 0 April 1, 2004 21:13
Could Fluent simulate random process? David FLUENT 0 September 6, 2002 10:49
NEW flow-induced noise module in FLUENT 6?? jon FLUENT 0 March 18, 2002 04:18
