Problem: calculating drag coefficient
Old   February 7, 2011, 04:55
Default Problem: calculating drag coefficient
RFH_student is on a distinguished road
i've got a problem i want to calculate the Drag coefficient of a Plate. I tried it in 3D but it didn'nt work, now i try it in 2D but without success. I use Fluent 6.2.16 and Gambit.
The Fluent settings that i used, ke Modell, 3m/s inlet velocity, reference value see in picture. Dimensions of the plate are 0,25m x 0,15m x 0,005m.
In literature the plate has a cd of nearly 1,1 but in fluent nearly 3 how is this possible and what do i do wrong? Have anybody got a tutorial or an example of an drag coefficient calculation for me? The Fluent tutorial 3 doesn't really help.
RFH_student is offline   Reply With Quote
Old   February 7, 2011, 09:02
DoHander is on a distinguished road
I suppose the k-epsilon turbulence mode you have used was activate on the entire flow domain, if this is the case ... let's the source of your error. See this article for the effect of using a turbulence model in the entire flow domain for low speed flows:
http://larcase.etsmtl.ca/PDF/Note-Paul-f.pdf
in Fig. 8 you will see a simulation similar with your own, using a turbulence model active on the entire flow can basically give you more than 50% error on Cd.
It is not too clear from your picture but your flat plate is vertical ?
Do
DoHander is offline   Reply With Quote
Old   February 8, 2011, 04:23
Hi Do,
first thank you for the fast answer and yes the plate is vertical in the flow.
Did I understand it right, is it neccessary to use more than one modell on the Mesh. How is it possible in Fluent?
RFH
Old   February 8, 2011, 08:36
Yes, you have understand correctly, see this thread for a similar discussions:
http://www.cfd-online.com/Forums/flu...same-time.html
Drag Coefficient for Ellipse Form (2D) Ketut Utama Main CFD Forum 8 December 11, 2014 11:03
Ammonia-liquid modelling. Problem with thermal expansion coefficient. zhekka FLUENT 0 February 9, 2010 15:06
Drag coefficient as a solver criterium sanchezz CFX 1 January 4, 2010 18:30
Plot drag coefficient against Y(distance) edwin FLUENT 0 February 4, 2008 09:41
about the drag coefficient maximus Main CFD Forum 7 April 18, 2005 19:00
