rotationally periodic properties vs temperature |
April 7, 2008, 13:13 |
Hi. I'm trying to model fluid flow between two rotating cylinders held at different temperatures with fluid viscosity depending on temperature. In translationally periodic flow its impossible due to the flow development. Is it so in rotationally periodic flows in fluent, e.g. if I'll model only a slice and not the whole 360degs. Thanks a lot.
Properties of air versus temperature AND pressure | Vincent | Main CFD Forum | 5 | July 28, 2008 06:28 |
temperature BC for periodic BC | qunwuhe@hotmail.com | Main CFD Forum | 0 | June 24, 2007 01:00 |
FIDAP and temperature dependent mat properties | semetay | FLUENT | 0 | July 11, 2006 13:45 |
Problem with transport properties depending on Temperature | galaad | OpenFOAM Running, Solving & CFD | 5 | December 6, 2005 12:51 |
Rotationally Invariant Methods | Praveen C | Main CFD Forum | 0 | May 14, 2001 13:11 |
