help for a simple UDF
Old   April 14, 2008, 07:21
Default help for a simple UDF
Greg
Hi I am writting my first UDF but I did programming a long time ago..
So as to set a non constant pressure boundary, I wrote:
#include "udf.h"
DEFINE_PROFILE(pressure_profile, t, i)
{ face_t f; real to; to=1.3e-3; real po; po=10.5e6;
i= po*(1-time/to)*exp(time/to); }
After I will have to compile this .txt file in Fluent thanks to Compiled UDF buld. Am I right?
Thank you for your help.
Greg
Old   April 14, 2008, 10:17
Default Re: help for a simple UDF
bohis
firstly, You wonīt succeed if you compile *.txt. It must be *.c Then you can proceed compiling, but your UDF isnīt complete anyway! Check it out!
Bye
Old   April 14, 2008, 10:53
RE13
Try considering including the following lines in your code:
-------------------------------------------- real time = RP_Get_Real("flow-time");
begin_f_loop(f,t) {
F_PROFILE(f,t,i)=po*(1-time/to)*exp(time/to); } end_f_loop(f,t) -------------------------------------------- save your file with a .c extension and put it in your workind directory. now you can compile and build the UDF. Maybe you need a pressure inlet to hook this UDF properly. When selecting the gauge total pressure, use the drop down menu to select the profile you compiled previously.
See the UDF manual for details on hooking the UDF to the solver.
Regards
About Phase Coupled SIMPLE (PC-SIMPLE) algorithm Yan Kai Main CFD Forum 0 April 18, 2007 03:48
About Phase Coupled SIMPLE (PC-SIMPLE) algorithm Yan Kai FLUENT 0 April 13, 2007 23:17
simple vof yang Main CFD Forum 0 November 18, 2005 08:19
Can i get help for SIMPLE Ramu Main CFD Forum 5 September 21, 2003 18:37
C++ & SIMPLE saba Main CFD Forum 3 December 3, 2002 22:43
