Under relaxation factors
Old   April 16, 2008, 16:32
Default Under relaxation factors
ro
In some cases in my work the solution is did not converge untel I changed the value of under relaxation factors My question is is changing of the value of URF affect the results i.e the accuracy of solution
thank you
Old   April 16, 2008, 17:26
Default Re: Under relaxation factors
rich
No, it will not affect solution accuracy as long as your solution converges (with certain mointor indications: residuals, force, surface...).
Old   April 17, 2008, 09:06
ro
is that is mean when I choice any value for these factors it will never affecting the results and solution accuracy just enhance the convergance.?
Old   April 17, 2008, 13:44
ALI
usually we use to set the URF at a low value that what generally it is suggested everytime , but it does effect the solution more over whenever your solution conveges it dosen't mean that the analysis u run is correct always cross verify ur results with contours , graphs and compare the theorotical value and and the values which were calculated from fluent.
only then you can say that ur proposed analysis is correct.
Relaxation factors Vidya Raja FLUENT 7 September 26, 2006 20:00
Under relaxation factors box... Help ! Cyril FLUENT 8 October 28, 2005 00:16
Relaxation Factors Tim Phoenics 3 June 30, 2004 02:03
relaxation factors zhujianguo Phoenics 1 August 5, 2003 06:17
relaxation factors Roberto Ciardulli Siemens 3 October 26, 2000 11:35
