Turbulent options for Karman flow behind obstacle?
Old   April 29, 2008, 03:36
Default Turbulent options for Karman flow behind obstacle?
donde
I am investigating square obstacle (size is H=1m) flow.
For this problem results Fluent calculated are in good agreement with experimental data only for laminar model: amplitude of lift force about 0.8, Struhal number Sh=f*H/V=0.15 (Reynolds number is 100000)
But for the turbulent models such as Spalart-Allmmaras or Srandart K-E model calculations shown sufficent oscilations smoothing by turbulent viscosity.
The Fluent options are: Turbulence Intensity 3% Turbulence Lenght Scale 1m
Old   May 6, 2008, 10:40
Default Re: Turbulent options for Karman flow behind obsta
Amr
You may want to search this forum for previous posts on this topic. Bare inmnd that your problem is time-dependant in order to give you the proper wake disturbances. Also, the choice of turbulence model is paramount (k-w, KW_SST, RK-E or RSM)
Amr
Pipe flow with obstacle - HELP Min FLUENT 6 January 31, 2017 14:28
2D flow over obstacle Martin Tauer Main CFD Forum 1 March 6, 2008 05:03
oscillating obstacle in 2 D channe flow Sumeet FLUENT 1 September 15, 2006 08:46
oscillating obstacle in 2 D flow Sumeet Main CFD Forum 0 September 14, 2006 14:45
Flow around a cubic obstacle - LES or DNS Neyval C. Reis Main CFD Forum 2 November 2, 1999 10:30
