logical cube for meshing was not able to found |
May 17, 2008, 01:02 |
Hi, while meshing my volume in gambit, i am getting an error message saying " logical cube for meshing was not able to found" and meshing it.. but, when i export that to fluent one of the interface in that volume is skipping, i tried mesh at different sizes of grid the same problem persisted.. kindly help.
thank you ss |
May 17, 2008, 05:39 |
Re: logical cube for meshing was not able to found
a non logical cube for meshing in gambit is for example a face that is made up of edges that do not meet. So take a small circle inside a large circle on the same plane. Then subtract the smaller from the larger to be left with an annular face. This is a face that cannot be constructed from its 2 edges directly in gambit and is a non logical cube. Workaround is to break the face up into smaller faces each having edges to do close.
Gambit help: Cube inside cube | Jack Martinez | FLUENT | 13 | August 11, 2010 06:29 |
Sphere in Cube | sameer jaju | Siemens | 9 | April 24, 2008 02:13 |
Sphere in Cube | Sameer jaju | FLUENT | 2 | April 15, 2008 19:13 |
Velocity of 3.5 for oscillating airfoil - logical? | quarkz | Main CFD Forum | 0 | April 13, 2006 00:12 |
Cd of cube | Naga | FLUENT | 1 | November 25, 2004 14:33 |
