how to launch a Parallel
Old   May 28, 2008, 11:59
Default how to launch a Parallel
maxim
hi everyone. I guess I'm really a noob 'cause I don't manage to lauch the ParalleL application.. when I use the commande line fluent 2d -t2 in the command prompt , the only answer i receive is : fluent is not a valid command name... so I need your help to identify the folder where I must be to launch correctly the application
Thanks
Old   May 28, 2008, 13:55
Default Re: how to launch a Parallel
BastiL
Does it run without "-t2"? I can not imagine... You did not add the location of the fluent executable to your path.
Regards
Old   May 29, 2008, 09:14
Paul
Try using the fluent launching application. It should be in your main fluent folder (Fluent.Inc\fluent6.3.26\launcher)
[OpenFOAM] ParaFoam does not launch lawrencelkl ParaView 7 July 20, 2008 09:32
Launch Michele Siemens 4 January 10, 2008 05:08
missile launch simulation Mark FLUENT 1 July 11, 2007 17:30
how to launch fluent from C code Hugo FLUENT 2 May 23, 2007 17:11
Launch ProStar in StarDesign ? ingear Siemens 6 October 28, 2005 12:21
