UDF problem
Old   June 8, 2008, 12:46
Default UDF problem
Eric
Dear all, when i interpereted a UDF source file gives the following error --- cpp: /daten/home/zxu/2d/sms/heat: No such file or directory Error: /daten/home/zxu/2d/sms/heat flux.c: line 1: syntax error.
I use windows. compiler is Visual C++ 2005. As the first line is the head file #include "udf.h", i am really confused. Please help me. Thanks a lot.
Old   June 25, 2008, 23:15
Default Re: UDF problem
wu
I was aslo encouted the problem,but have not found the solution.what about you now ? Can sharing your solution?thank you.
VOF diffuse problem on two fluids problem Fang Jin FLUENT 5 February 17, 2011 05:38
Problem in Modelling Heat Transfer Problem Deepak R FLUENT 1 December 6, 2007 09:37
Problem in cavity flow problem saad Main CFD Forum 4 November 1, 2007 07:45
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
problem in solving "wave generation" problem san FLUENT 2 April 3, 2006 23:37
