Conjugate heat transfer problem in 3D
Old   June 15, 2008, 16:41
Default Conjugate heat transfer problem in 3D
Tanveer
hi all
I am solving 3D Conjugate heat transfer problem.... but when I export mesh file into fluent.....coupled boundary condition is not there in "define boundary condition" panel.. can I do somethng in fluent to assign coupled BC or I have to edit the geometry in gambit itself.... can anyone tell me how to make geometry so that coupled BC would appear in fluent.....
Thanks Tanveer
Old   June 17, 2008, 02:15
Default Re: Conjugate heat transfer problem in 3D
Rakesh Jha
Generally it should appear if the two domains share the same face. I guess you have non-conformal mesh and the domains do not share any geometric entity.
(i) define the two domains (solid and fluid) in gambit itself. (ii) define interface (solid-fluid). Go to Fluent -> Define -> Grid Interface -> select appropriate surfaces and apply. (Switch on the coupled option there).
Conjugate heat transfer problem Soheyl FLUENT 2 March 15, 2008 14:15
conjugate heat transfer problem Andreas Main CFD Forum 3 February 7, 2002 12:57
conjugate heat transfer problem Andreas FLUENT 2 February 6, 2002 03:15
conjugate heat transfer problem Andreas CFX 1 February 5, 2002 18:22
conjugate heat transfer problem Andreas Siemens 0 February 5, 2002 08:00
