About the divergence when using unstructured mesh |
June 21, 2008, 08:29 |
HI ALL,
I AM DOING A PROBLEM OF EXTERNAL FLOW ON A CYLINDER AT M=2 AND 10 DEGREE ANGLE OF ATTACK. I HAVE MADE A COMPLETE TET/HYBRID MESH. I KEPT THE CFL NO LOW TO 0.2 BUT AFTER 3000 ITERATIONS IT DIVERGED. THEN I RAN THE PROBLEM AGAIN AND INCREASED THE CFL NO SO THE DIVERGENCE CAME AT 1600 ITERATIONS. SECONDLY, BEFORE DIVERGENCE IT GAVE ME SO MANY WARNINGS LIKE TIME-STEP REDUCED IN 3 CELLS TEMPERATURE LIMITED TO 1 IN 2 CELLS IN ZONE 2 (DEFAULT-INTERIOR) ABS PRESSURE LIMITED TO 1 IN 3 CELLS IN ZONE 2 THE PROBLEM IS OF 2 MILLION CELLS SO I RUN IT ON 3 COMPUTERS ON PARALLEL TELL ME HOW THE DIVERGENCE PROBLEM CAN BE SOLVED? |
June 22, 2008, 05:58 |
Re: About the divergence when using unstructured m
Hi! you may regulate the underlaxtion factor ,it has a direct effect on convergence, let your problem work at first with the default ,after some iterations , decrease the factor to 0.3 or 0.4 . it may works.
June 22, 2008, 09:00 |
Arash, Thanks for ur reply but I am running the simulation at Inviscid and coupled(Density based) solver. I do not get any option of Under-relaxation factor in it. It comes only in either a viscous solver or using Seggregated (pr based) solver
Divergence problem - NOT the mesh | Carlos | FLUENT | 1 | August 2, 2008 09:38 |
About the divergence when using unstructured mesh | SHAMOON | FLUENT | 4 | June 20, 2008 13:17 |
Structurted mesh and unstructured mesh | Wiroon | Main CFD Forum | 4 | July 1, 2005 04:41 |
Structurted mesh and unstructured mesh | Wiroon | FLUENT | 2 | June 28, 2005 09:40 |
divergence of moving mesh | ricklee | Siemens | 2 | June 27, 2005 03:53 |
