Can GAMBIT edit element or nodes ?
Old   July 4, 2008, 23:10
Default Can GAMBIT edit element or nodes ?
pongup
I am a beginner looking for a meshing tool for CFD (FLUENT, in particular). GAMBIT is recommended by many friends of mine. But can GAMBIT manually edit elements or nodes ? My work will involve a complex geometry. I expect difficulty in meshing, which I may have to fix it manually. If GAMBIT cannot do it, what tool should I look for?
Thank you very much.
Old   July 5, 2008, 16:42
Default Re: Can GAMBIT edit element or nodes ?
BastiL
what is a "complex geometry"? For really complex geometry use a third party tool for surface meshing and T-Grid for volume meshing.
Regards
Old   July 8, 2008, 08:32
umcad
hi,
Gambit can't edit elements & nodes but Tgrid has the capabilitiy to do so. you may use Tgrid as secondary meshing tool.
maximum no. of nodes/cells which GAMBIT can handle Sanjay Jain FLUENT 0 April 2, 2008 09:54
Multiple hanging nodes in GAMBIT Partha Main CFD Forum 0 March 12, 2008 00:16
Gambit/Fluent: limit of nodes, edges or volumes? Ralf Schmidt FLUENT 10 October 5, 2006 01:47
edit NACA with Gambit Br FLUENT 0 July 16, 2004 16:43
Gambit problem: reading the nodes Li FLUENT 2 June 10, 2004 13:20
