problems with STEP file
Old   August 1, 2008, 17:51
Default problems with STEP file
ertan
Hi Guys,
I had a point cloud obtained from a laser scan of a manikin. The point cloud was stored in a STL file. Using a software called 3DReshaper I processed the point cloud and obtained a water-tight model for the manikin. And I exported the file in STL and STEP format files.
When I imported the STL file to GAMBIT, GAMBIT created a virtual face, which allows me to create only virtual volumes. But I don't want virtual volumes because it limits my Boolean operations. (I have to subtract this volume (manikin) from a bigger volume (wind tunnel) to simulate the flow around the manikin.)
Therefore I had to go with STEP files. However, the STEP file (which holds only data of triangles (facets)) created by 3DReshaper did not work with GAMBIT. I could not figure out the problem yet. Here is my first question: What kind of data (facet data?, surface data? or something else)should a STEP file contain in order to be succesfully read by GAMBIT?
Since I could not find a way out to import the STEP file to GAMBIT, I decided to use Pro-E to create another STEP file just to check if the problem is with 3DReshaper. Therefore I imported the STL file (which was succesfully read by GAMBIT) to Pro-E. And I saw that Pro-E took data as facets. (Gambit had taken it as a surface. It may a translation issue.) Anyway, the I export the facets as STEP file again and GAMBIT failed in reading again
As a way out, I decided to convert those facets to a surface and export the surface in STEP format file. However, I could not do that because of my insufficient knowledge in Pro-E. If you guys know how to do that and share your knowledge with me I would deeply appreciate.
If you guys have some experience about the issue I wrote, please share them with me. Any ideas, suggestions to get around the problem is highly appreciated.
EK
geometry import problems (STEP into ICEM) Toralf CFX 10 March 7, 2014 21:17
autosave dat.file at flow times -w.adapt.time step jsn FLUENT 1 January 11, 2008 19:30
time step in free surface problems KtoTo Siemens 4 June 26, 2007 07:03
writing a dat file at each time step ayapan FLUENT 4 September 30, 2005 01:07
gambit 2.1.6 and step file Wenbin Song FLUENT 3 August 31, 2004 10:17
