Boundary conditions for rotating fan
Old   July 21, 2008, 02:33
Default Boundary conditions for rotating fan
rohit
I want to know, which type of boundary conditions should be given to rotating machines case? (turbomachine). I want to simulate a cooling fan, and I want to predict performance curve then which type of boundary conditions should I chose?
Old   July 21, 2008, 10:54
Default Re: Boundary conditions for rotating fan
jesse
you will use Rotating Reference Frame, that means, non-slip BC on the wall, while wall is given an rotating speed;
inlet:total pressure outlet:static pressure
Old   July 23, 2008, 04:33
Raj
use pressure inlet and pressure outlet boundary condition. also make fan blade as moving wall.
Old   July 23, 2008, 04:53
rohit
Thanks a lot buddy. But I am confused, why should we use pressure and not mass flow rate? Pls answer me.
Old   July 23, 2008, 04:59
Raj
yeah u can use if u know mass flow rate at inlet..
Old   July 24, 2008, 00:26
rohit
Hi raj, Thanks a lot. But could you tell me which one will be better (pressure or mass flow) ? And why???
Boundary conditions for rotating fan rohit Siemens 3 October 4, 2008 04:18
Boundary conditions for rotating fan rohit Fidelity CFD 3 September 24, 2008 07:18
Boundary conditions for rotating fan rohit CFX 2 July 22, 2008 09:20
Boundary conditions for rotating fan rohit Main CFD Forum 0 July 21, 2008 05:45
Boundary conditions for rotating fan rohit Main CFD Forum 0 July 21, 2008 02:31
