dynamic mesh not working
Old   July 22, 2008, 01:01
Default dynamic mesh not working
studentwhoneedshelp
I am new to dynamic mesh and I need your help. I have created simple box model which I wanted to rotate at z axis at certain rotational velocity. I want to see the outer domain mesh changes according to the rotation of the box. If this simple model works, I will use the same method to more complex model. Please check the model using these links.
Full model with BCs: http://img235.imageshack.us/img235/4...is8fullfb0.png
The box which is set to rotate at z axis with omega = 0.2 rad/s: http://img133.imageshack.us/img133/1...smallbozt5.png
The box (solid volume) rotated, however the outer domain didnot change following the movement of the box: http://img401.imageshack.us/img401/4...rotatedfk4.jpg
The box volume was rotating, as you can see from the box-shadow BC. However, the outer domain (box BC) didnot change.
Can you please help me to set the case. I believe that there is something wrong with the case setting.
Thanks
Old   July 22, 2008, 04:17
Default Re: dynamic mesh not working
krishna
You have to write a UDF to rotate the rigid box. Use DEFINE_CG_MOTION and with options such as Smoothing, Remeshing. Regards,
Old   July 22, 2008, 05:18
studentwhoneedshelp
Hi Krishna,
I am trying to write the udf file now. I am currently reading the sample for the udf with define_cg_motion.
What is the symbol for omega (angular velocity)? Should we set it ourself? They only have example for force and axial velocity.
I want to assign constant angular velocity to the box. At the end of certain period of time, I want to know the moment with respect to the box's cg.
Thank you
Old   July 23, 2008, 09:00
studentwhoneedshelp
I wrote this simple udf file to rotate the box at z axis with omega = 0.2 rad/s.
#include "udf.h"
DEFINE_CG_MOTION(boxtwo,dt,vel,omega,time,dtime)
{ /* reset velocities */
NV_S(vel, =, 0.0); NV_S(omega, =, 0.0); if (!Data_Valid_P()) return; omega[2] = 0.2; }
Then when I tried to attach it to the box (volume), I got this error message. Can somebody please show me where is the error.
Warning: incorrect cg motion UDF boxtwo on zone 2 (assuming no motion)
Thank you
Old   July 24, 2008, 03:31
krishna
keep the mesh file and the udf in the same directory. you have to load the file in to the solver by using compile option. DEFINE->USER-DEFINED->FUNCTIONS->COMPILE->udf.c and built and load it. You may have problems if you do not have a C compiler. Better load VC++ if you are working on windows operating system. ReGARDS,
Dynamic Mesh Pj FLUENT 1 March 12, 2007 15:16
Help: Basic steps to get dynamic mesh working CH FLUENT 4 November 6, 2006 09:38
dynamic mesh - structured or cooper mesh Manoj Kumar FLUENT 2 November 11, 2005 01:18
dynamic mesh and sliding mesh nasser FLUENT 0 November 1, 2005 02:37
dynamic mesh sam FLUENT 0 November 1, 2004 23:16
