Stability test using fluent possible or ????
Old   July 25, 2008, 05:59
Default Stability test using fluent possible or ????
Novice
Hello all,
Is it possible to test the stability (or strength) of a structure against the flow of a liquid(say water) in FLUENT.
Here i am explaining my problem: I have a Cylindrical tube of dimensions 500mm diameter and 2m length. There are about 10 glass rods are placed in the cylinder from one end and from the other end water flows into the cylider. Now i would like to calculate the stability of the glass rods against the water flow. Is it possible to solve this problem in Fluent? if so please let me know the procedure.
Thanks in advance
fluent for stability derivatives....?!?! naomi FLUENT 0 August 10, 2007 01:02
Fan Perfomance Test on Fluent abhinit FLUENT 1 January 8, 2007 12:39
Shock-tube test in Fluent queram FLUENT 0 July 5, 2006 15:35
test cases for Fluent and Gambit Ben FLUENT 1 May 21, 2003 06:44
Tracer Test on FLUENT Priyal Main CFD Forum 1 August 27, 1999 11:13
