Particle sample file doesn't match R-R distributio
Old   August 21, 2008, 16:55
Default Particle sample file doesn't match R-R distributio
Grant
I'm injecting DPM particles into a 2D flow using the Rosin-Rammler size distribution method. I've matched the exponential function from Fluent's user guide to the actual particle distribution.
The problem is that the mass distribution of particles being injected doesn't match the exponential function at all.
I've searched through all the previous posts on this topic and I haven't found a solution. I realize that Fluent injects a uniform number of particles for each size, but that the mass distribution should match. But in my case it doesn't.
Thanks for your help.
Urg: Particle tracks discrete phase summary sample fivep FLUENT 5 July 21, 2014 04:48
Rosin-Rammler Sample File Grant FLUENT 5 December 2, 2011 14:48
export particle traking file Neser CFX 2 March 3, 2007 06:53
Saving particle (DPM) data to file? Philip FLUENT 2 June 12, 2006 01:41
How to report the particle trajectory to a file Devy FLUENT 0 January 11, 2005 09:26
