About the iteration panel.
Old   August 27, 2008, 10:00
Default About the iteration panel.
MK
Hello everybody I am analysing an unsteady problem via Fluent. In the iteration panel, we must fill Time Step Size, Number of Time Steps, and Maximum Iterations per Time Step. I can not understand these items very well, especially their relation with the convergence. You see, when the problem converges, Fluent doesn't stop iteration. Why? Another problem is that I do not know how to specify the Time Step Size and Number of Time Steps Values? Regards.
Old   August 27, 2008, 17:54
Default Re: About the iteration panel.
NRD
Since you use an implicit time stepping, FLUENT iterates for each time step. For unsteady case, when FLUENT says that the solution is converged, it means, the solution has converged for that time step and then it will move forward in time.
You can specify time step size depending on the CFL condition
Old   August 29, 2008, 08:16
MK
Dear NRD If at the end of iteration the problem did not converge, should I change the problem parameters and do the iteration again? Could you please introduce me a reference on this subject? Thanks a lot.
Old   September 4, 2008, 12:18
NRD
That's correct.
If the solution does not converge for the number of iterations that you specified then you can try reducing the time step and rerun the simulation. If you are not particular about the level of accuracy then you can just specify number of iterations and run it even if the case does not converge at each time step. Since it is implicit time marching, the code is unconditionally stable (i.e. code will be stable even if the time step is quite large but will degrade the accuracy).
FLUENT documentation is the best reference on this.
3D Panel Method Daniel_Cro Main CFD Forum 0 September 19, 2008 03:44
help 3D panel method sam Siemens 1 June 25, 2004 14:26
help 3D panel method sam CFX 0 June 22, 2004 04:17
Panel Method Zeynep Cehreli Main CFD Forum 5 February 8, 2004 05:24
Panel Method Dayton Main CFD Forum 0 June 3, 2003 15:12
