September 4, 2008, 01:38 |
Burner Sketch for liquid fuel combustion
Hi Forum Users, I desperately need some burner sketch that can actually burn both liquid and gas fuel. I read a lot of literature on combustion but to start i need some kind of a sketch of a burner. If anyone can provide with the same that would be highly appreciated. Thankyou for your time Ashwin.C.Punjabi
September 4, 2008, 13:45 |
Re: Burner Sketch for liquid fuel combustion
Yes, these can be quite difficult to locate. The good thing is if you just want to set up a generic case, you can look at schematics or cutaways of burners found on webpages for burner vendors. Look for Coen, Todd, or Hamworth-Peabody. These should give enough information on size, geometry, air flow path, swirl, etc.
If you need to model a specific burner, then you would likely have all the geometry info needed. |
September 4, 2008, 23:39 |
Hey Allan, Thankyou for the information. Any sketch would almost be a patent and so it would be impossible right to get. well i will look for rough schematics to work Thankyou Ashwin.C.Punjabi
September 7, 2008, 12:00 |
hi! I am looking for a burner which can utilize less consumption of OIL (LDO), please let me know the details where the capacity should be atleast 50L. My contact me on 9811539029. Madan Mohan Mittal. or else please drop a mail on the above mentioned email id "manishgupta01@indiatimes.com".
September 7, 2008, 23:32 |
Hi manish, how are you? Firstly which industry does your burner have application for. secondly there are dual fired , staged fuel burners available in plenty of models. fine tune your requirement and check out johnzink, hartworthy peabody, they are burner manufacturers. hope this helps thanks ashwin
Please help with liquid fuel combustion modelling | tom | FLUENT | 4 | October 17, 2014 21:08 |
liquid fuel combustion | camby | CFX | 0 | April 26, 2007 21:32 |
Help! Warnings on liquid fuel combustion | Julie | Siemens | 0 | August 31, 2004 10:58 |
combustion chamber for liquid fuel | Kirill | CFX | 1 | November 18, 2002 10:07 |
Liquid fuel combustion | Yong-Ju Hong | FLUENT | 3 | May 17, 2000 04:27 |
