y+ Adaption reverse flow
Old   September 12, 2015, 03:34
Exclamation y+ Adaption reverse flow
tomss
tomss is on a distinguished road
I've a problem in Yplus adaption. My case was multiphase, turbulence k-e with enhanced wall treatment, species transport. Im gettin the converged done. but when I try to adapt Yplus between 1<x<5 then suddenly the reverse flow happen. but after several iteration it converged again. can i used the result of it?
Thank you
tomss is offline   Reply With Quote
Solution is converging but have reverse flow on pressure outlet Dinesh_Dhande Main CFD Forum 2 March 11, 2018 01:02
Eulerian Granular flow:receive reverse flow and solution isn't converge bahman FLUENT 1 January 2, 2014 11:53
momentum & x-vel convergence, and reverse flow problem cinwendy FLUENT 0 April 17, 2013 02:19
Flow simulation in reverse drum mixer Patel Chirag CFX 0 July 19, 2010 15:05
Reverse flow in the VOF model yan FLUENT 1 May 26, 2005 09:14
