S2S model
Old   September 16, 2008, 02:48
Default S2S model
mandar
hello sir,
i have some problems about radiation modelling in S2S:
here is some description of problem :: square 2D cavity bottom hot top cold side walls adiabatic
i am using S2s model but i see that it is not giving correct results for the low emissivities
e.g.top bottom 0.5 and side walls 0.1
Radiation Heat Transfer Rate (w) -------------------------------- --------------------
bottom 0.22598088
left 0.00022241924
right 0.00030250785
top 0.12082574
Net 0.34733155
but it gives accurate results if i keep e=1 for all (for checking this i have kept gravity=0 and k =0 for air so that i get only radiative heat transfer)
one more absurd thing is that if i keep one of the top or bottom e=0 it gives like :
bottom 0
left 0.00020713897
right 0.00024958443
top 0.017235142
Net 0.017691865
which actually should be close to 0.
this is what i find problematic
maximum iterations exceeded in radiation calculations. Radiosity unconverged after 5 iterations Final radiosity residual = 2.983e-003
can you please guide me regarding this ?
(emissivity i give in the internal emissivity)
waiting for reply
mandar
Population balance model for twofluid model pierre OpenFOAM Running, Solving & CFD 9 March 19, 2016 13:46
Surface Reaction Model or Heterogeneous Rxn Model? satheeskannan FLUENT 0 September 2, 2008 18:55
changing model constants in k-e turbulence model Sunil CFX 3 October 3, 2006 12:12
Symmetry model half or total geometrical model in LES vvqf OpenFOAM Pre-Processing 3 March 22, 2006 09:06
Copying boundary conditions from model to model Lior FLUENT 3 September 23, 2004 16:10
