July 23, 2013, 07:21 |
species transport-outflow boundary condition
Rep Power: 15 |
Dear all,
I am simulating a species transport inside a geometry with several outlets and I am using th outflow boundary condition. My question is: does this boundary condition only fix the total flow (like for outflow:0.25-->25% of the total fluid-mixture is passing through this outlet) or is also the amount of species is fixed by the outflow condition (like also exactly 25% of the species is forced to pass this outlet)? I am afraid the latter might lead to wrong results, since depending on the bifurcation the amount of species might be larger or smaller at an outlet... Does anybody have an idea or a reference? Thanks a million! Lilly |
July 28, 2013, 13:00 |
A-A Azarafza
Rep Power: 14 |
Hey
Off course, the first one is correct, a portion of total mass flow.
Regard yours |
August 2, 2013, 03:24 |
Rep Power: 15 |
These are good news! Thanks a million for your reply!
August 30, 2013, 12:22 |
Vikram M.
Rep Power: 15 |
Dear Lilly,
I am looking to model something similar - contrast agent in blood through a realistic geometry of an artery with a stenosis. I am interesting in seeing the concentration of the agent downstream of the stenosis. However, I am new to the species transport model. I have been reading around and so far I understand that I would need an inlet mass fraction for the dye and the diffusion coefficient to use the species transport model. I will assume a zero flux through the wall but I am not sure what outlet bc to use. I only have 1 outlet. Should I be prescribing a mass fraction at the outlet ( I don't have this information) ? or just use the outflow condition. Thanks for your input in advance Vix. |
September 4, 2013, 04:59 |
Rep Power: 15 |
Dear vix,
since I am interested in how the contrast agent bolus shape looks at the outlet I am using the outflow boundary condition and I do not set a bolus shape there. But you could also use a pressure outlet for example. I don't think you have to fix the mass fraction of the species at the outlet there (even though you have the possibility to do so). Do you have information of how your bolus looks there? Good luck, Lilly |
September 4, 2013, 05:58 |
Vikram M.
Rep Power: 15 |
Hi Lilly,
Thanks for your reply. I do not know how the bolus looks at the outlet so I guess using either an outflow condition or a pressure outlet would be sufficient (without specifying a mass fraction) I am mainly interested in seeing if there is an increase in the concentration of the species downstream of the stenosis as there is a recirculation zone which occurs there. Would you be able to help with a few questions I have as I go along this simulation ? I would really appreciate it. For example, when you select the species transport model, you are supposed to select a mixture. What mixture have you chosen ? or if you have created your own mixture, is it just the contrast agent and the blood. What properties would you need to specify for the two ? I read somewhere that the agent should be first and the blood should be second since blood is the bulk fluid. Is that correct ? Thanks for your help Vix. |
CFX fails to calculate a diffuser pipe flow | shenying0710 | CFX | 7 | March 26, 2013 04:13 |
Outflow boundary condition for convecction-difussion problem. | juanelo14 | Main CFD Forum | 0 | September 27, 2012 00:20 |
asking for Boundary condition in FLUENT | Destry | FLUENT | 0 | July 27, 2010 00:55 |
vorticity boundary condition | bearcharge | Main CFD Forum | 0 | May 14, 2010 11:32 |
outflow boundary condition foe flow over a cylinder | Ardalan | Main CFD Forum | 0 | April 29, 2010 13:04 |
