how to simulate exchanger?
Old   October 7, 2008, 11:31
Default how to simulate exchanger?
Feimi
my model is: the hot-water pipe has small diameter (inner) , and the cold-water pipe has big diameter (outer). the heat tranfer from the hot-water through the steel pipe to the cold-water. boundary condition: (1)fliud1 (hot-water): velocity-inlet(0.1m/s) , outflow , T=640K (2)fliud2 (cold-water): velocity-inlet (0.1m/s), outflow , T=610K (3)solid : steel (4)wall (outside of cold-water pipe ): heat flux=0 because the Re<2300 , the problem is a liminar flow. the model seems no error i think. however, the reslut is dispointed me. the residual is always flat and very large;the cold water flow incorrect. i don't kown why it is , and i guess two reasons: (1) the model set has mistake or (2) fluent is not excellent to simulate this kind of problem which is the soild and fluid heat transfer couping
Old   October 8, 2008, 09:59
Default Re: how to simulate exchanger?
chandra manik
What residual?, energy residual? If you wan heat transfer occured in this model, you have to beware on the boundary wall between two difference material " Shell boundary" where the konduction or convetion constant need to be stated. You also have to turn on the energy solver.
Old   October 9, 2008, 07:39
Feimi
i have already turned on the energy solver
How to simulate Plate Heat Exchanger Summer FLUENT 4 February 17, 2022 01:37
HOW TO DESIGN AND SIMULATE HEAT EXCHANGER... fadly CFX 1 August 14, 2007 15:40
How to simulate 3D shell and Tube heat Exchanger san FLUENT 2 February 22, 2006 05:44
How to simulate mass transfer in heat exchanger? Yang Bin FLUENT 0 January 17, 2005 06:35
Heat exchanger mkiku FLUENT 1 July 21, 2004 09:53
