internal cooling of gas turbine blade
Old   October 20, 2008, 15:20
Default internal cooling of gas turbine blade
vinay
hi guys,
I am interested in finding out the temperature distribution of the gas turbine blade. Essentially, there is external flow of gases at higher temp over the blade and also, there is flow of coolant (i'm assuming air of lower temp) through the internal passage in the blade. I'm am not clear as to how I should go about this. It would really be helpful if someone could elaborate.
modeling cooling holes in turbine blades rajesh kumar gupta Main CFD Forum 1 September 9, 2010 12:13
Turbine film cooling simulation Lorenzo CFX 1 September 9, 2010 12:13
Cooling of a turbine blade - Injection of coolant PA Main CFD Forum 0 June 16, 2007 07:19
Turbulence model for turbine blade cooling CFD Student FLUENT 0 December 20, 2004 08:30
laminar/turbulent internal cooling flow Fabien Coppens Main CFD Forum 1 April 14, 1999 12:55
