Boundary & Initial Cond. with Different Fluent ver |
October 22, 2008, 04:33 |
does anybody know, if you can read in boundary and initial conditions from newer fluent verions into an older fluent version? Reading the case file causes Fluent to crash, whereas the mesh file works fine. Any comments are very much appreciated. Many thanks, Peter |
October 22, 2008, 13:46 |
Re: Boundary & Initial Cond. with Different Fluent
How far back are you going? V6.3 to 6.2 or 6.1? Back to version 4?
Some times Fluent complains when reading case files from newer versions into older ones, but can still calculate. Are you using "read-bc" to read in the bc's and conditions? You probably know that you can use a text editor to edit the bc file and may be able to modify something not supported in the older version. And, of course, you can interpolate the data files for different versions. |
November 2, 2008, 17:00 |
I am trying to transport the bc from 6.3.22 to 6.1.22. The write/read-bc command does also not work, even from 6.1.22 to 6.3.22. Has anybody advice how to manipulate the files in an text editor? |
Boundary cond. - need a paper- | CFD Student | Main CFD Forum | 0 | December 14, 2004 11:47 |
Boundary Cond. in Supersonic flow | Doctor Blade | Main CFD Forum | 16 | September 7, 2004 13:37 |
Boundary cond. to UDS | ramesh | FLUENT | 1 | May 30, 2004 06:19 |
Periodic Boundary Cond. | Mohammad Kermani | Main CFD Forum | 0 | November 7, 2000 01:52 |
Boundary cond. in staggered grid | Chatterjee | Main CFD Forum | 1 | August 11, 2000 06:15 |
