Smagorinsky Dynamic Cosant in UDF
Old   October 28, 2008, 07:53
Default Smagorinsky Dynamic Cosant in UDF
Paolo Lampitella
Hi, i'm performing some tests on the LES module of Fluent with the turbulent channel flow.
I wrote an UDF to export my data in an external file but i can't find the Dynamic Constant in the variables. That is:
C_U(c,t) is the x_velocity
C_V(c,t) is the y_velocity
C_W(c,t) is the w_velocity
what is the command for the Dynamic Constant?
If there is not such a command, do you know if the following one:
C_MU_T(c,t)
which is the turbulent viscosity, is also valid with the LES model?
Thanks
Old   June 17, 2009, 03:40
sla
Slawomir
sla is on a distinguished road
If it is needed for postprocessing you can extract a dynamic constant Cd by
Cd = mu_t/(rho*SQR(delta)*S);
where
mu_t=C_MU_T(c,t);
rho=C_R(c,t);
delta=pow(C_VOLUME(c,t),0.333);
S=Strainrate_Mag(c,t);
sla is offline   Reply With Quote
Smagorinsky model sylvain91 OpenFOAM Running, Solving & CFD 0 June 22, 2006 06:29
Dynamic Smagorinsky LES Lourival FLUENT 0 April 14, 2006 13:48
Dynamic Smagorinsky Model Andrew Main CFD Forum 1 November 30, 2004 00:52
Reply to Tim Re Dynamic Smagorinsky model Ajay S. Parihar Main CFD Forum 9 June 2, 2002 16:24
Dynamic Smagorinsky model Tim Main CFD Forum 7 May 29, 2002 07:37
