Need help about multiphase flow
Old   November 6, 2008, 11:36
Default Need help about multiphase flow
Shafayat
Hi, Can any one suggest me about which model to use?
I will modeling air bubble in water. Water is the primary phase. Also i will use K-e model for turbulence. I can't figure out which one to use---DPM or Mixture.
Thanks for any help.
Old   November 6, 2008, 15:37
Default Re: Need help about multiphase flow
CDE
Are you modeling dispersed air bubbles or one large air bubble?
Old   November 6, 2008, 16:33
Shafayat
I will be modeling many dispersed bubbles.
Old   November 6, 2008, 16:53
CDE
you can use the Eulerian or Mixture multiphase model for this. If there is significant slip velocity between phases I would recommend using the Eulerian model.
Multiphase flow for flow around ship gundul CFX 5 September 2, 2008 16:06
Multiphase flow João fernandes FLUENT 2 August 6, 2007 19:12
multicomponet flow vs.Homegeneous multiphase flow klarke Main CFD Forum 5 October 10, 2006 22:10
multiphase flow lily FLUENT 1 January 30, 2005 23:00
Multiphase flow Karthick FLUENT 7 February 23, 2004 10:05
