multiphase flow
Old   November 5, 2008, 22:26
Default multiphase flow
poiu
hellow:
My problem is to simulate the flow in a three-phase reactor.Water and biogranules are put into the column reactor,and then,air flows into the bottom of the column and take water and granules flow together in the reactor.
My question is how to set the initiate volume conditions? Can i use the region adaption to set the initiate volume proportion? Who can tell me something about the region adaption?
Thanks!
Old   November 6, 2008, 15:39
Default Re: multiphase flow
CDE
Use region adaption to mark the area you want to initiate volume fraction. Then use solve->initialise->patch to set the volume fraction on the cells you marked.
Old   November 6, 2008, 19:45
poiu
thanks!
Need help about multiphase flow Shafayat FLUENT 3 November 6, 2008 16:53
Multiphase flow for flow around ship gundul CFX 5 September 2, 2008 16:06
Multiphase flow João fernandes FLUENT 2 August 6, 2007 19:12
multicomponet flow vs.Homegeneous multiphase flow klarke Main CFD Forum 5 October 10, 2006 22:10
multiphase flow lily FLUENT 1 January 30, 2005 23:00
