relation for yplus and heat transfer
Old   November 14, 2008, 05:10
Default relation for yplus and heat transfer
selvag
Hi, Can anyone help me in understanding what would happen to the heat transfer prediction if wall yplus is above 300 for standard 2 equation models? whether it will predict more or low value?
Thanks
Old   November 14, 2008, 05:36
Default Re: relation for yplus and heat transfer
Amit
For accurate computation of wall fluxes(Heat flux etc.) computation smaller yplus is required. it varies with turbulence models. for example with spallart allamaras model it can be either less than 10 or more than 50. for higher yplus u may not get the accurate heat transfer predicition, inviscid fluxes are not affected by yplus. Further details u can find in manuals.
Regards Amit
Old   November 17, 2008, 01:29
selvag
Thanks Amit, if i choose large yplus, say 350 in 2 equ model. whether it will overpredict or underpredict the result?
Forced convection heat transfer in heat sink Sidy FLUENT 1 October 18, 2008 03:27
flow/heat transfer through heat sink (with fins)? Pei-Ying Hsieh Main CFD Forum 1 January 26, 2008 06:33
HEAT-TRANSFER & EXCHANGE HEAT MODEL Problems Jordi FLUENT 1 March 31, 2006 10:30
Heat Transfer Coeff. at Heat Flux Boundary Rushyen CFX 6 January 18, 2001 05:09
heat transfer coefficients with "bad" yplus Andrew Main CFD Forum 4 April 8, 1999 04:43
