November 19, 2008, 07:22 |
sliding meshes
Hello. I am attempting to simulate the rotation of a water turbine using sliding meshes. The fluent manual states that if 2 zones are meshed independently, it is necessary to merge them. Does this mean that for all sliding mesh problems it is necessary to use t-merge, or can this be done without the use of t-merge.
Also when 2 interfaces assigned in gambit are combined to make a single grid interface, walls are created as boundary zones. Does the fact that these are specified as walls make a problem, and what boundary condition type should they be changed to if so? Thanks. |
November 19, 2008, 15:27 |
Re: sliding meshes
try to use Tgrid instead which is more convinient that tfiler tmerge
November 19, 2008, 15:32 |
Re: sliding meshes
import two meshe files in Tgrid and save them as one mesh file can be read in fluent
November 20, 2008, 08:20 |
Re: sliding meshes
Hi Tim
Regarding your gambit query ------Even if you define walls in gambit to interface zones you can change it to interface b.c. in Fluent. For naming conventions you can use Rotor:intf1/Casing:intf1 as in your case for turbine. which would be easier for you to find the couple on interfaces defination panel in fluent And do remember to change the b.c. of these intf# to interface b.c. from boundary condition panel... Hope so i have understood your query and answered ..... if its different we can discuss.....to resolve it...... Uday |
sliding meshes | GU | FLUENT | 0 | May 9, 2006 06:50 |
Sliding meshes | Vijay | FLUENT | 0 | December 16, 2005 00:47 |
Sliding meshes and meshing | Joel | Siemens | 0 | September 9, 2002 06:35 |
Arbitrary Sliding Meshes | Anna | Siemens | 0 | September 1, 2002 06:02 |
Sliding meshes-compressible. | Pierre Ricco | FLUENT | 1 | March 8, 2001 06:10 |
