udf - c++ compiler does not work
Old   January 6, 2009, 19:01
Default udf - c++ compiler does not work
Matthias
Hi everybody,
I would like to use a udf, but when I try to compile an example from the manual, I get the error:
'nmake' is not recognized as an internal or external command, operable program or batch file.
I am working with Win xp and installed Microsoft Visual 2008 c++ on my machine. But in the faq it says that I have to enable the "register environment variables" option. I could not find that during the installation. Could anyone please explain me how to do that in detail? That would be really great help!
Thank you, Matthias
Old   January 9, 2009, 00:44
Default Re: udf - c++ compiler does not work
Davy
you may need to read instructions in Visual 2008 on how to enable the environmental variables.
UDF compiler michilin FLUENT 2 January 3, 2007 10:24
Gcc compiler shuo OpenFOAM Running, Solving & CFD 1 October 7, 2006 04:15
set compiler f77 andromeda Main CFD Forum 0 July 9, 2006 08:35
Compiler for UDF Alamgir FLUENT 5 July 31, 2002 20:44
compiler stephanie FLUENT 2 June 19, 2002 07:49
